I've learned a lot about towing over the last couple of days, and am still uncertain about some things with the wiring.
I drive a 1998 Explorer 4D 4WD 4.0L XLT. I am making a one-time haul 1000 miles there and back. The trailer is small and has a 7-round connection. I am not going to connect the brakes nor the power wire to the trailer battery and am only interested in the lights. I am doing this on as much of a shoestring as possible. I do not (believe) I have the towing package. I am still trying to figure out what tranny I have. I have amber rear turn signals.
I have read a lot and have visited the Ford dealership and NAPA several times. I have a doctorate (not in wiring) so I'm not exactly dense. I get a little frustrated with answers (such as from the dealership) that start with: "Generally, maybe, probably it should work...[without toasting your computer or other electronics]" I am under the impression that wiring is either right, or not...sort of an all or none thing...
The Ford man looked under the truck where I showed him the wiring jack. He confirmed that is IS a wiring jack and said that it "looks like" it has the brown and yellow and other wiring. (I'll look myself tomorrow; either it IS wired, or it is not)
At Ford Parts, I was delighted to find that Ford has a part (13A576) that plugs directly into this jack tucked up behind the bumper under the car. This harness will magically turn the jack underneath the truck into a 4-flat. The Ford man said I should be good to go. I can adapt the 4-flat to a 7-round (lights only) with a part from Napa.
Also at Napa, I located something that looks just exactly like the $51 Ford part for less than $16. (755-1547) Problem is that it's described as being for my truck WITH the tow package which I believe I do not have.
There is another Napa part (755-1566) for $82 that requires a bit more installation the most difficult of which would be running a wire to the positive pole of the battery. I can probably handle that.
See, the $82 Napa [Hopkins] part has a little power converter and also mentions a fuse assembly. The $16 part is pretty much just a harness with the right connections that appear to match the Ford part.
So, my dilemma is this: Which to get??? $82 or $16? (+4-flat to 7-round)
I asked the Ford man about overheating things and needing a fuse. He said there's already a fuse in the truck's fuse box. I asked which fuse? --to which he said "it should be labeled 'acc', as in accessory" Later, looking in my manual I found two fuses involved with trailer lights, (#30 and another)...there are none labeled "acc". Are those two involved fuses enough?
Now, might these Ford guys be kind of ~forgetting~ to tell me that I'll roast my expensive truck computer if I don't have some kind of converter? Am I just too unforgiving about the "maybe"s and "should be"s ??? Am I pressing too hard for a definite answer?
I just want to take my son's stuff to him for school...and now I'm in a quandary...should I just buy the $16 Napa part and see how it goes? Am I taking too big a risk?
What to do?
I wish SOMEone could tell me what is it about the factory Tow Package that makes it OK and risk-free to use the cheaper part.
Sorry for the long post; hopefully there's enough information for a relevant and useful solution.
Thanks you in advance,
drcarl
PS - If someone happens to know where I can find my tranny specs, that'd be cool, too...
From what may be relevant from the sticker inside the door (I have no clue what all these might indicate) :
RC: 56
WB: 112
BRK: 4
INT TR: ZE
TP/PS: P/
R: K
AXLE: 46
TR: D
SPR: BF
What to do?
drcarl
RC: 56
WB: 112
BRK: 4
INT TR: ZE
TP/PS: P/
R: K
AXLE: 46
TR: D
SPR: BF
