doonze
- May 16, 2009
- Fayetteville, Ar
- '93 X Sport
I know only about 5 people in the whole world will ever find this interesting and informative, but for all 5 of you, here it is.
This is of course specific to a 93 Explorer, but I'd think most other 1st gen 91-94's would be the same. This is the control that has OFF - MAX A/C - PANEL - PNL/FLR - FLOOR -FLR/DEF - DEFROST mode selector. The Push button A/C/Fan control and the standard Blue/Red temp control.
This is all verified on my truck through several different states of repair.
Firstly, if the A/C-FAN button is PRESSED, and the little orange light is ON, your A/C compressor is running and your condenser is condensing, irregardless of what other settings are on. So MODE can be OFF, and FAN can be OFF, but if the orange light is on your A/C is running, period.
"Now when does the A/C run when the light is NOT orange, and the button is NOT pressed" you ask? Well I'm glad you did! That would be when it's in DEF/FLR or DEFROST mode on the MODE SELECTOR. Once again irregardless of other settings if the selector is in either of those two modes the A/C is on. However the light will NOT light orange in those modes unless the button IS pressed. But then it's orange anyway so meh....
Moving on... outside venting vs. recirculated air, and the direct reason I know all this now for sure. The ONLY 2 modes you can use to get Recirculated cabin air is OFF and MAX A/C. ALL OTHER MODES OPEN THE OUTSIDE AIR VENT.
***If you get air from the vents even with the selector in OFF and MAX A/C, and the fan is also OFF, read my 2 threads about fixing this issue.
HERE
AND HERE
Also of interest, OFF and MAX A/C from all my test appear to be really the same thing. The only thing that changes in fact from OFF to PANEL when moving the selector is that when you get to PANEL it opens the outside air vent. So, if you want A/C or heat, recirculated and from the vents only.... OFF and MAX A/C both work the same for doing that. MAX A/C doesn't appear to have anything to do with A/C at all, heat works just as well in that mode. It only seems to be a PANEL setting where OUTSIDE AIR is shut off. I think OFF is just there to make us feel better. So if the mode selector is OFF, and you turn on the fan and hit the A/C button, you get cooled air from the vents. Same if you slide the temp control over to hot and hit the fan. Hot blown air from the vents. So OFF on that control means nothing.
The fan works normal. OFF IS OFF, and there are 4 speeds of fan. Push the button and it turns the A/C on, and the orange light comes on. Press it again and the orange light goes out and the A/C turns off. (except in FLR/DEF and DEFROST modes where the A/C is on no matter what the other settings)
The temp control is normal as well, nothing weird there. Blue is cold/Red is Hot.
Some other interesting facts. If LOW on the fan control is too much air for you, but you would like to have A/C cooled air flowing in the cabin slide the temp to cool, put the mode on PANEL and the Fan to OFF and press the A/C button. You will now get outside vent air cooled by the A/C. Course if you stop moving there is no longer any cool airflow.
If you can't seem to get it warm enough, or you want it to warm the vent air quicker, put it on MAX A/C, Fan on a setting you like, and temp control to hot. This will close off the cold outside air and use the warming up inside cabin air instead. So it will warm faster and get hotter. However you can't use this with floor settings, that opens the outside vents again.
As a side note, I've owned over 20 cars in my life, and this one has the strangest control system I've every seen on a car. My 68 Mustang was wack, but not THIS wack.
Just thought someone might search for this one day and it might help them figure out what is SUPPOSED to happen so they know if they got a problem or not. And also shed some light on how the silly thing works. I'm sure everyone who has a perfectly working system knows all this, but for those like me who had a broken system for 2 years and didn't know because I thought it was normal, this threads for you!! LOL
HERE
AND HERE
