VA7LFD
- July 12, 2015
- Langley
- 1994 Limited Edition Expl
Weird question, by the way thanks for all the info. and help from all of you here in keeping my 94 Explorer Limited Edition running the past many years.
Here it is I have not been able to get proper heat in the passenger compartment. I have no leaks from the heater core or cooling system itself. The blower fan works perfectly. I went to check the vacuum valve for the heater and I actually snapped it ( cheap plastic piss me off ) I am in the process of going to buy a new one tomorrow or next few days. So I can operate the vehicle I pulled the valve and directly hooked the hoses from the water pump to the heater core thinking that will verify my problem. I still have the same problem it doesn't come up to the proper temperature when heat is on. Yet if its a really nice day say 55F or above the heater works unbelievably well and right up to temp. Again there are no leaks anywhere. Oh almost forgot the A/C is not working. There is a hole in the condenser and the system has no refrigerant in it. Don't really care about the A/C right now. Just at a loss.
Should I check for air in the system, thermostat problem, controls for the heater temp. adjust are faulty? Anything else?
Thank you from Vancouver BC. Merry Christmas to all....
