I've never heard a wheel bearing make such an intermittent clicking, that seems to roughly coincide with the wheel position. Since it does it without the wheel on, we can rule out the rim being warped and wobbling on the rotor (though with alloy rims, would probably crack long before it warped that far in), so I'd wonder if it's the CV axle. Is the grease boot for it in good shape?
Then it does seem like it's the hub/bearing, but that's a fairly unusual sound it is making, and this makes me wonder about something. You re-torqued to 160 but if that is only the max spec for the tool, it is possible the tool doesn't really make that much torque and it is close to or below the lower limit for axle nut torque which based on one source I saw was 157-213 ft-lbs.
Could just be that the hub was defective but it's surprising for SKF, they usually make good hubs so you didn't make a bad choice in using one. It's also surprising to make that sound rather than a more continuous metallic grating noise.
Now I'm confused, I saw your vehicle reads "4X4" and thought this meant you have hub-integrated (not separately replaceable) bearings, but based on your prior post about replacing just the bearings, I double-checked Rock Auto and they list both hub-integrated bearings, and separate bearings for AWD/4WD.
Next I did a forum search and found the following topic, where you linked a video plus the posts, leaving me even more confused because I thought this all in one type hub assembly, had to have preload from the axle nut or would quickly wear out, and yet what I *think* I'm seeing in the video is the integrated hub on a 2x4, not a spindle/bearing assembly which couldn't be on a 4x4 ??
Wheel Hub/Bearing Question
Is it possible to buy a wheel hub and bearing already pressed or is that just not a thing? I cant seem to find one already pressed anywhere. Its for a 2004 explorer xlt btwwww.explorerforum.com
Thinking about it more, is this due to use of an aluminum knuckle and it's simply too weak for a spindle which is why they starting using a new setup?
Whether you have an integrated hub or separate bearing arrangement, they should not need replaced often if using major brand parts. I wonder if the mechanic somehow damaged the bearing when installing it, but even then, the sound it is (if it is) making is odd.
lol, I give up, ignore my posts and wait for someone who knows this setup better. That includes ignoring my post about "definitely nothing to do with ABS", if you have an external ABS tone ring, if it could rub against something.
You asked earlier about a 6 ton press -- I have the rears done by shops, so I'm not sure, but I remember a video on YT saying it takes a 10 ton press
I had mine done on a 30 ton, when I came back to pick the knuckles up the boss said it was maxed out and made all the men leave the bays until it popped loose with a bang. YMMVYou asked earlier about a 6 ton press -- I have the rears done by shops, so I'm not sure, but I remember a video on YT saying it takes a 10 ton press
Agree 100% Tech.But mine's been done somewhat recently and multiple times. Usually only the first time is that hard.
