glfredrick
- January 25, 2003
- Louisville, Kentucky
- 86-98 Ranger STX
The trick is to get the inner nut tightened to just the right level to pre-load the bearings, then tighten the outer nut until you lift the front end of the truck off the ground from the force you place on the tool.
That typically works to keep them tight.
I use two people to tighen them. One to hold the socket in place so I don't slip off and round it off, the other to work the end of the 4 foot pipe I have slipped over the breaker bar.
FWIW, I never had any problems with mine coming loose, even after driving the truck across the nation, and wheeling the snot out of it repeatedly. Also didn't have many failures running 33s. I did use Amsoil synthetic grease...
