Rob1234
- November 2, 2005
- Sterling, Virginia
- 1997 XLT
Hello
I have a 1997 Explorer XLT 2WD 4 Door V6 (not sure if it's SOHC or not) with 150,000 miles on it. (and relatively no complaints up to this point).
Two days ago I was low on gas so I got about $10 worth and went on about my business. About 15-20 mins later it started hesitating and idling rough intermittently. It progressively got worse, to the point of barely running and the Check Engine light came on. I figured I got bad gas/water in my tank.
Figuring it was water in my gas I put some HEET in the tank and let it run for about 15-20 minutes and the hesitation/stuttering went away at idle. I drove it to the store near my place and it ran fine for the first 2-3 minutes then started hesitating again. Drove it maybe 1 mile or so further and it hesitated/bucked and just died.
Coasted into a parking lot and now it won't start. It cranks, it tries to turn over but just won't start. Occasionally it will almost turn over, or it will turn over and start to run but then almost immediately it will die again. Fuel gage says I have about 1/4 of a tank which sounds about right, and I'm on a SLIGHT incline but with the front end higher than the rear.
I tried starting it with a jump (jumper cables), no change. I pulled each cap off of the ignition coil deal on the top right hand side of the motor and each cap is getting spark. (side note, if I disconnect the electrical connector that goes to the side of the coil housing obviously I get no more spark but the engine sounds the exact same when trying to start it).
I checked the air filter and it's slightly dirty but even with it pulled out the engine won't start.
I don't have a computer tool to hook up and pull the code but I may go get one if it's required.
What should I/could I check that's relatively easy to do sitting on the side of the road before either buying a code puller or towing it to a shop ?
IAC ?
MAF ?
Fuel Regulation/Fuel Pump electronics ?
I have little experience with working on this specific truck but am fairly competent in general, but I don't have a Haynes Manual or the owners manual/wiring diagrams on me.
Any ideas would be greatly appreciated.
Regards
Rob
IAC ?
MAF ?
Regards
Rob
