5R55E VB Bolts - Location Template | Ford Explorer Forums
S
  • Media owner Spuddy
Print out this template and tape it to the side of a box. Punch holes through the template and box at each screw location with a #2 Phillips. Then push each screw into its proper hole as they are removed, so you know where they go!
To print this out as large as possible:
1. Right-click picture and save to your computer
2. Right-click on picture on your computer and select Open With and then Paint
3. Picture will open in Paint. Click File then Page Setup
4. Select Orientation as Landscape, change all Margins to 0 (note that each will revert to some minimum value), then select Scaling as Fit to: 1 by 1 page(s) - Click OK to close Page Setup
5. Click File and Print to print
Stock Vehicles
Spuddy
5.00 star(s) 1 ratings
