ggomez2
- December 23, 2009
- Denver, CO
- 2007 Ford Explorer EB 4.6
Hello all!
First day of cold weather out here in Denver, and go figure, I barely had any heat.
Recently replaced radiator.. did hoses, new thermostat at that time as well. Did the work about 1 1/2 months ago, and no issues noticed with running temp of truck between then and now.
Weather this morning was 39 degrees, and while I sat idling for about 5 minutes I realized there was no heat from the ducts. Usually this truck heats up fast. Drove about 5 miles home through downtown, engine temp needle never moved from cold. No hot air from vents. I also noticed the top radiator hose didn't feel all that hot, but also it was very stiff; I feel like when water runs through it it's hot but also a bit pliable. I did touch the two heater core hoses and they didn't appear to be all that warm, either. Coolant level seemed ok judging from the expansion tank. Over first few weeks after the radiator replacement, I kept an eye on the radiator coolant level and seemed fine.
Any suggestions? Thanks for your insight, in advance! Love this forum for all the information I've gotten owning this '01 for last 2 years.
