mac999993
- June 6, 2006
- Newtown Square, PA
- 02 XLT
I've read many many threads regarding the Explorere Transfer Case Shift motor issues, but haven't found one which addresses the condition when you push the 4x4 High or 4x4 Low button and the Light remains OFF - particulary for an 02 Explorer. When I press any of the 4x4 dash buttons (Hi, Low, Auto), nothing happens - No noise, no clicking, no light. I'm thinking it must be a disccnected wire harness or loose wire somewhere... Read below why..
Background:
In short, my son recently backed my 02 Explorer XLT over top of my neighbors freshly cut hedges... Don't ask!
I had to have a tow truck to have it removed.. the bushed actually lifted the truck off of the wheels enough to limit traction, and I couldn't hack my neighbors bushes completly down..
After the tow truck removed the truck from off the hedges, I noticed two things:
1) The ABS light came on - I found a disconnected wire harness from the rear speed sensor on the rear differntial. I reconnected the wire harness and that problem went away.
2) The 4x4 no longer works - Can't figure out the problem YET -- HELP! I looked around the 4x4 transfer case to see if the wire harness had been damaged on disconnected.. NOPE. I've tried to locate a diagnostic procedure to help me locate either something damaged or, more likely, a disconnected wire/harness. I figure that it is most likely a loose wire/harness since nothing happens when I press any of the buttons. Any Ideas? How can I troubleshoot - continuity tests, trace wiring for breaks, disconnects, etc. Hint: The bushes definitely were rubbing hard along the entire undercarriage during the tow truck removal process.. All I could do was GRIMACE!
Also, I presume that the 4x4 control module located behind the glove box (unlike the earlier generation Explorers which is located in the left rear panel by the jack). Is there a white button test on this generation 4x4 control module?
I would appreciate any help.. Thanks.
Background:
