02 explorer computer swap? | Ford Explorer Forums
ningakiller
elkton maryland
2002 ford explorer
I have a 02 explorer it had a theft light blinking so I called a locksmith he came out and said the computer was probably fried because it wouldn't communicate with his scanner I have another 02 for parts can I swap pcm s
Are you using a non chipped key?
if you have the keys from the parts car then you can but you have to swap the ignition and door lock cylinders. it's probably a question for the locksmith if he could do the programming after the PCM swap in case you don't have the key from the parts car.
Also, check the fuses - I had a car where the data jack ran off the cigarette lighter fuse, which was blown. Car ran fine, but scan tools wouldn't work until the fuse was replaced.
I do have the keys!! does the pcm have to be reprogrammed too or just the keys? its the same year same model (xlt)
