gforceman
- April 7, 2003
- Virginia beach VA
- 2003 limited 4.6 V8
ok , everytime i shift from reverse to drive or drive to reverse and press accelerator i hear a CRACK from the center or close to front of truck i thought maybe the U-joints but NO there tight , motor mounts are ok as well , maybe internal ? tranny or transfer case have any of u guys heard this- the flange at the tranny was replaced due to a updated flange before i bought it .. also the a seal on the drivers axel is leaking bad at the differential - maybe fluid is real low now and im hearing a low growel maybe a bad rear - i used to work for ford and Alot of explorers came back for bad rears--- any thoughts thank you
OR just let ford fix it ??
