my 03 eddie 4.0 does the same thing , i thought it was comming from the intake releasing vacuum after shutdown or power brake booster , releasing vacuum
I have the same thing in my 02 sport. As soon as the engine stops its whines for a second or two then stops. And I've been searching all over the site with no luck
If that winding sound is a result of the clutch giving out, does anyone know how expensive it is to replace? Whatever happened to the days of free estimates?
I have a 2003 Explorer. Just started doing this did anyone ever find out what that sound of winding down when turned off is? Please I am getting ready to go on a trip with an elderly parent...don't want a breakdown if I can avoid it. Thank you anyone...
My 02 XLT 4x4, does the same thing every once in a while. Too bad we can't get it to do it when it is in the garage, with the hood up. Question to ponder, What is still turning after you turn off the motor,when parked? The only thing I can think of is the cluch fan. Welcome to other Ideas.
I am leaning to a fan clutch assembly. I have the same issue, but have not addressed it yet. I am too busy with broken off studs on the passenger rear wheel.
i am having same symptoms any one figure this out i have replaced alternator, idler pulley, belt, and belt tensioner pulley but no fix the noise kinda sounds like a turbowinding down when turning the engine off
problem solved.... it was the belt tensioner, i replaced belt tensioner pulley, idler pulley alternator, and fan clutch but nothing changed, so i finaly got a long tube and listened through it at the tensioner hope this helps some people having same issue
