The wife's 02 explorer 4.0 flex fuel has started loosing coolant with no obvious signs of a leak. I have checked the oil and spark plugs for signs of coolant and nothing. Ive changed the thermostat housing (that was leaking) and thermostat. it has now gotten to the point that I can fill it with coolant and within 5 miles its overheating. Could it be a bad thermostat sticking shut? If so wheres the coolant going? Just had back surgery so I cant climb around under it but my wife and daughter say they cant see any leaks under it. Could the water pump be bad? I know on the old 302's when the pump would go it would leak out the weep hole but I'm not sure on these. Any help would be greatly appreciated.
Thanks
Thanks
