jrobie79
- December 27, 2010
- Boston, MA
- 2002 Limited 4.6 VIN "W"
So to recap my recent problems with my 4.6:
Noticed an occasional 6th cylinder misfire code, very random, and not often.
Figured I'd get new plugs as part of my new ownership maintenance. Also noticed I was using up oil at a higher than what seemed normal rate - I check it all the time, just a habit.
Fast forward to this weekend, I popped off the engine cover and noticed liquid oil pools right around the valve cover/coils/boots/injector area. Like little pools of liquid oil - not just fuzzy sprayed oil on surfaces. I also noticed the 6th cylinder spark plug hole has been repaired, with some sort of extension, that put the plug electrode about 1" above where it should be - I a fixed that with a helicoil, and snugged down the plug and thought all was good in terms of the misfire...
Friday after this repair I left from Boston to Montreal - made it up there fine - checked oil, and coolant, all seemed fairly unchanged. Today when we went to leave, I immediately get two codes from my OBD bluetooth adapter - I checked because I felt the bogging - 5th and 6th cylinder misfire. Stopped and pulled off the coils, wiped the oil from them and went on my way. 5th cylinder code disappeared - 6th still there...going to replace all plugs and coils, so we'll see what that does to the misfire code. now onto the confusing part:
I noticed when I dropped my buddies off, a good puff of blue smoke after accelerating from a stop - and its running even worse (only code still 6th cylinder). I check the dipstick, it's down to about the last millimeter of the cross hatched area ( I topped it up to about 7/8 coverage on the hatched area before leaving this morning).
Would a leaking valve cover AND leaky intake manifold cause any of the leaked oil to drop into the intake and burn up upon accelerating from a stop? Didn't notice any blue smoke while driving, just acceleration from a stop. What else would be the oil consumption? I already bought a filter housing gasket, changing that tomorrow but I'm concerned with the liquid oil on top of the engine.
