02 Mountaineer AWD Rear Clutch Packs | Ford Explorer Forums
dwonzer
I am getting the, what seems to be common, shudder at low parking lot speeds when I am turning. I talked to a guy at Ford and he said that it sounded like the rear clutch packs sticking. Any thoughts. I do most work on my own vehicles and am wondering how big of a job this is. Ford quoted me a price of around $1500 so that usually a job i can do for a few hundred myself. Any input on confirming that is what is might be and then any instructions out there on replacing them?
Whats the door code for the Axle, my AWD has an open rear end, code 45. Do you have the Class III hitch?
its a code 45 which is a 3.55 non-limited slip i believe. I do not have a class 3 hitch although i would like to. I just have the class 2 stock one.
that means you have no clutch packs . . . .
Is yours AWD? No switches on the dash.
my bad, i see the AWD in the title now, might want to look up viscous clutch. They also have the same symptom to confirm 90% remove the front drive shaft, if it goes away more than likely its the viscous . . .
I will be out of town for a while here but when I get back i'll pull that drive shaft and let you know what I find. Thanks for the help
finally pulled the drive shaft
Well it finally got warm enough to get out in the garage and pull the front drive shaft. The skip went away and so did a humming sound that I though was a bearing. Guess I'll have to get a different transfer case. Do you think its better to just find another or to pull the transfer case and have it rebuilt?
If the the problem is gone its i'm 90% sure its a failed viscous, they fail open or locked.
If you pull a junkyard, you might get the same problem, it would have to be low mileage before i would feel comfortable, and a cheap price.
Check on Rebuilds if its over 100k . . .if it gets up there in mileage its well worth it imo. I've had two heep with blown cases, one reman ran $800 and to install another $350, second time around i found a great trasn and gear shop and it only ran $650, it now has 70k on the rebuild and no issues.
Last guy couldn't find a Viscous unit as no one is selling retail, they run about $400 last time they where out there. Crate ReMan is an option, or if you can pull it and take it to someone?
there was a post in the last month or so about the same thing. . .
