y3kbuddy
- February 21, 2003
- Beverly Hills, CA
- 1996 Sport
just failed my smog check cuz of the O2 sensor. Wanted to see if you explorer geniuses knew which one I need to change. the ODB Fault code is:
"PO133 O2 Sensor Slow Response (Bank 1 Sensor 1)"
Checking on autozones website, it says there are four. I went there in person and the guy said there were two. Can anyone help me with this. How many are there? Where are they? and with the info provided, which one do I need to change?
The location of the four given on the autozone website are:
1) UNDER HOOD, PASSENGER SIDE, UPPER ENGINE AREA, MOUNTED ON EXHAUST MANIFOLD
2) UNDER HOOD, CENTER, REAR ENGINE AREA, MOUNTED IN EXHAUST MANIFOLD
3) UNDER VEHICLE, PASSENGER SIDE, BELOW SEATING AREA, FRONT OF CATALYTIC CONVERTER, MOUNTED IN EXHAUST PIPE
4) UNDER VEHICLE, PASSENGER SIDE, BELOW SEATING AREA, MOUNTED IN EXHAUST PIPE IN REAR OF CATALYTIC CONVERTER
Thanks in advance to everyone.
