Spleeb
- December 13, 2013
- Huntsville, Al
- 2002 Ford Sport Trac
Hi Folks,
I am new to the forum and in need of help. I have an '02 Sport Trac with a P0171 Code (twice I did get a P0303). I have never had a P0174 so I am tending to believe that my "lean bank one" issue is related to something unique to the passenger side.
Problems started a while back when truck started running rough. Mechanic diagnosed faulty fuel pump and replaced it. It does run some better but still runs rough at all times (warm, cold, idle, and under load). Long Term Fuel Trim is high ~20%-25%.
I have checked for vacuum leaks and found one on PCV Valve elbow. Repaired it but no joy.
I suspect maybe a faulty fuel injector (thus the P0303). I used a piece of tube to make a stethoscope and noticed the injector on passenger side closest to firewall didn't have the healthy "tap, tap, tap" the others had. This could be my imagnination but I think it to be true.
Any ideas on other things to try in terms of determining the problem would be greatly appreciated. Sorry for the long post but I thought the more details the better. Thanks in advance.
