2000StreetRod
Moderator Emeritus
- May 26, 2009
- Greenville, SC
- 00 Sport FI, 03 Ltd V8
lower pressure?
If the gasket for the oil filter/thermostat housing casting is bad or if the casting is cracked flow should be in the direction of least pressure. Normally, I think the oil pressure exceeds the radiator pressure. In that case there would be oil in the coolant instead of coolant in the oil. What is your oil pressure vs your radiator pressure? You might try a low pressure radiator cap to see if that makes a difference. If your oil pressure exceeds your radiator pressure then I suspect your coolant leak is where the oil is not pressurized.
