04 Explorer - No Crank/Start, Stuck In Neutral | Ford Explorer Forums
skittle021
2010 Explorer Eddie Bauer
Hey guys, first post here.
My neighbor has a 2004 Explorer that she recently bought from a local dealer. The car was having issues with an O2 sensor when she bought it, but that has since been replaced. However, after replacing the sensor, she began to have all kinds of electrical problems. She gave me a list of notes, which I will retype below.
According to her, she replaced the O2 sensor, then plugged in an OBD scanner to see if there were any other issues. The scanner noted numerous problems, but the car was still drivable. However, the other day she got in the car, and it would not start, and eventually got stuck into neutral (not sure exactly how that happened if it would not start). At the moment, anytime she attempts to start the car, it simply clicks and most of the dash lights light up/blink, etc.
Anyway, I'll post her notes below, just checking to see if you guys have any idea why it may be stuck in neutral/will not start.
NOTES:
- RECENT REPAIRS:
- new brake pads
- new starter
- new neutral safety switch
- oil change
- ERROR CODES/ISSUES
- Code C1440
- Cruise Control
- Part #3L3Z9F924AB
- Codes C1233 + C1234
- brake tone-ring (needs cleaning?)
- Code 61676 (or B1676 - can't read writing)
- Battery Pack
- voltage out of range
- ABS Blown Fuse: Anti-Lock System
- ABS Module Harness is opened/shorted
- ABS Module Connecter
- poor electrical connection
- Faulty Charging System
- Faulty ABS Module​
I am relatively new to DIY repairs, as my father has worked for a Ford dealer since I was a child - so any repairs that were done were through a dealer, so I'm not really sure what could be going on here. I would've just suggested for her to take it to my father and have it checked out, however, with it not starting, that would be tremendously difficult, as the closest trusted dealer is over 1.5hrs away.
Anyway, any help at all would be appreciated, and if you need anymore information, just ask and I'll do my best.
Cheers
New battery is needed before anything else can even be addressed
It's stuck in Neutral because the brake-shift interlock is electrically operated and won't shift into or out of park without pressing the brake pedal.
Replace the battery and it should shift into park.
