06 Explorer 4.0, cleaning the injectors without removing them | Ford Explorer Forums
Gene619
Chicagoland
06 Explorer,94 Ranger
In order to clean the fuel injectors on this model year using a air pressure operated cleaning device, you have to disconnect the emergency fuel cut-off switch located in the passenger front panel. Carefully remove the panel to do this. I found that removing the fuse or fuel pump relay will also disable the power to the injectors, the engine would not turn over. The fuel pressure on my 06,4.0 is 60,..good luck.
