bpd9
- September 23, 2013
- Tucson, AZ
- 2006 Explorer Limited
Hello everyone, just got myself an explorer, new to the forum! So a few weeks in, the first morning it was cool out enough to turn my heater on, the temperature gauge started jumping. Now a few days later is continues to jump at at speed. It will raise up from right about halfway to the 3/4 mark, never making it all the way to red, then will suddenly drop back down a bit and kind of move around from there. Then when I slow down or drive under say 20mph the temp gauge goes right to where it should be. From past experience with other cars this tells me there has to be air in the system somewhere. Especially since the heater kicked on for the first time since I've owned it and that's when the problem started. Only now it happens regardless of outside temperature or whether I have AC on or heater or anything. I've tried burping/bleeding the air out to no avail. I had it running for a good 30 minutes with the front end jacked up and heater blasting. Think I should just try to flush the system out and fill it from empty to make sure there is no air? I'll check the tstat at that time as well, but is there anything I'm missing or any suggestions? Thanks all!
