06 explorer wont drive need advice | Ford Explorer Forums
richard84
oklahoma
06 eddie bauer 4x4
when car is driven the traction light and 4x4 light come on and the car grabs and pulls. i have checked the tone ring. i recently changed the front brakes and replaced the seal on the front differential a couple days/miles later this started any advice would be helpful it is an 06 explorer eddie baurer 4x4
I would check the wire going into the bearing / hub assembly since you just had things apart in that area. The abs sensor for the front is integrated into the hub in the front.
I would check the PCM. If in 4x4 on dry ground the wheels will grab. I had something like this happen on my 02 XLT and had to change the PCM. It worked until Icracked it up some 30k after. My 06 XLT goes into 4x4 without any interference
You changed the pinion seal on the front differential? I'm assuming that you put the yoke back on the pinion exactly where it came off. I changed the seal on mine also and I was very careful when I put the yoke back on. I'm not sure what would happen if I put it back on wrong, but just adding my .02.
