07 Mounty stock Amplifier question | Ford Explorer Forums
Vypre
Columbus, GA
2007 Mercury Mountaineer
So i just recently bought an 07 Mounty and pulled some of the old stereo equipment out of my old pilot and looking to install it here. can anyone tell me what the specs are on the stock amp? right now i work two jobs so time is limited and am prob gonna do the job in phases as far as eventually replacing all the speakers and the stock amp. I currently have a Fosgate P3sD210 - http://www.rockfordfosgate.com/produ...tails/p3sd2-10 which is a 10" shallow mount, dual 2 ohm sub. I want to drop this into the stock location along with some polyfill and use the stock amp as Phase 1. I have looked at a number of threads outlining how to get to the sub/amp but wanted to know what the specs of the amp were before i go through pulling everything apart....thanks
Hmm, not sure about the factory amp on a 2007. You mean the factory subwoofer amp?
It should be able to run the sub, but don't expect it to get the power it needs to run properly.
