9richard9
- February 17, 2013
- 1997 Ford Explorer
stays all the way to the right, outside of the gauge range; even when the engine is off.
No other indications that engine was overheating; radiator was down about a quart of coolant.
1997 Ford Explorer, V6, about 188K miles.
2) At the same time (about 2 weeks ago) this appeared, I noticed my low fuel level light (directly above my water temp gauge) turned & stayed on, even though my fuel gauge continues to work properly.
3) On a very cold morning, about 3 weeks ago, when I started the truck, the starter sounded different upon cranking the engine.
Ever since, each time I go to start the truck, it sounds like the starter strains a few seconds (appears to get longer with each start) before cranking actually occurs and the engine then starts.
I had the battery tested yesterday and it fine / OK, and fully charged.
While I think all these items are unrelated, and that the low fuel level light issue might be due to a bad float in the tank, I'd appreciate your input.
Thanks.
Rich in Central New York, USA
Thanks.
