midiout
- June 19, 2007
- Buffalo, New York
I have used both oils - the 5-20W gives me much better mileage on the expressway. When I had the oil changed the second time, they put 5-20W instead of conventinal 5-30W. I found out later after getting 25.5 MPG, that "they" put the 5-20W instead of Ford recommended 5-30W. With the 5-30W , I could'nt get past 20 mpg. From now on, I will stick with Ford 5-20 semi-synth and Ford 820S filter. When I changed the oil last sunday, the Valvoline filter (V02) was two inches shorter then the Ford filter. The Ford service dept. says which oil does'nt matter. What are other members thoughts on this ?
