TheEvilZX2
- May 27, 2015
- ZX2s, Explorer and a CBR
Well I signed up here yesterday because I was happy the explorer was running good after all these transmission problems it has been experiencing. Well now I'm 40 miles from home and the truck doesn't seem to want to shift out of first gear.
Here's a quick background on what has transpired over the last month or so to get you up to speed.
Truck lost 2nd gear and O/D Off was flashing. Pulled trans pan and found a piece of broken band. Had transmission rebuild at Ford, installed transmission with new torque converter and a nice big trans cooler. All was well for 5 days then it started flashing OD/Off again, ECU throwing incorrect 1st and 3rd gear ratio codes. Talked to the guy at Ford who rebuilt the trans and he wanted to take a look at the truck. It was left with him for a few days, he adjusted the bands and installed a shift kit. All was well for that weekend when on the way to a local gun show I hit the highway and the truck wouldnt engage 4th gear, started throwing 2nd and 4th gear incorrect ratio. Brought it back to the guy at Ford who said he couldn't find anything wrong but suspects a sticking valve in the valve body so $300 later we put a TransStar valve body in it with all new solenoids. This is where I stand now.
I've put 280 miles on the truck since I got it back with the new valve body, today I take it to work and all is well until I go to leave the office. 4WD lights started flashing at me and the truck doesn't want to shift out of first. I was able to get it to shift into second gear after getting some speed and feathering the throttle. My scanner does not pull any codes at all at this point.
I've read tons on the forums about problems with shifting, the only two items that I haven't touched on this truck that are mentioned on the forums are the TPS and ECU. I just ordered a used F5PF-12A650-BSA on ebay it will be at my door in a week. And if i can limp the truck home I will be able to test the TPS.
I was able to borrow a 8mm socket to disconnect the battery, I'm going to see if anything has changed when I get back out there.
Anyone have any suggestions for me? Anything I might have overlooked? Any tips/tricks? Do the 4WD lights have anything to do with this issue? Would the transfer case be my next point of interest?
This truck is going to be the death of me.....I'm all ready down $1200 into it trying to get it fixed, and I really don't want to give up on it. Everything was running so well yesterday.
