1995 ranger ECM location/replacement | Ford Explorer Forums
FrankLarrabee
Covina, CAL
1995 ford Ranger Xcab
Hey Guys,
I have a 1995 Ranger 4 Cyl that I believe has to have the ECM replaced. I'm not sure of its location?
The coil paks have been replaced, and # 2 is still miss firing.
Thanks.
Should be next to the brake booster down in the corner of the fender and firwall
Ecm
Thanks,
I can see it there.
How do I remove it?
Looks like it has 2 bolts holding the wire connectors there on the fire wall side?
From the inside, under the dash, it looks like it has a wire harness clipped to it?
Has one bolt in the middle that holds the wire harness. .then 2 bolts hold it in the firewall..i can get mine out without pulling a ton of crap out..there is a good youtube video that ahow it
[Youtube]zw4ODEs_xrw[/media]
O crap..just noticed yours is a 95..not 100% sure if its the same.sorry
No problem, it looks similar though.
I'll keep looking to be sure. Thanks.
