ericsmoore
- August 23, 2015
- oregon
- 1996 Ford Aerostar
this engine misses badly but on an intermittent basis. it generally happens at highway speeds (45 to 65 mph) and usually when beginning to pull a grade the check engine light activated one time only and the code indicated that low fuel pressure was detected I changed the fuel filter out recently with no luck. I don't know whether to head in the direction of the fuel pressure regulator or fuel pump. When it begins to miss all I do is back off on the gas and it stops missing it really doesn't do this at speeds under 40 or 45 mph maybe I should change the gas cap before I do anything else does this problem sound familiar to anyone? thks
