4rd Xplora
- May 3, 2010
- On a Round Rock in Texas
- 2005 Explorer Eddie Bauer
OK, my 96' E.B. is still having a problem with the a/c. Fixed the blend door problem and replaced the low pressure switch. The a/c worked perfect for all of half a day, then the a/c compressor stopped working. I replaced the lo-pressure switch again and it worked for about 20 minutes and then again for the same results. I have no power showing at the lo-pressure switch connector but can jump it from the battery and the compressor kicks on. It shows a reading of 35-45 on the low side when it's working. Now mine has the nomally "bullittproof" EATC but I'm at a loss on which wires to check. I've taken the EATC unit apart to check for broken connections and wiggled the little "black box" inside it. Nothing seems to work. Found a deal on the "Bay" that offers to rebuild the EATC unit with a lifetime warranty, but before I do that, I'm looking other things to check. Have read a ton of posts on this site but none seem to fit my problem exactly, but then my eyes have glazed over from reading. Should I replace the hi-pressure switch?
