1997 Ranger 4.0 no check engine light has no power also when it is really cold will stall when driving in gear | Ford Explorer Forums
Kilekilopa
Colorado springs Colorado
1997 Ford ranger 4.0
Lost of power acceleration is really slow have no check engine light on
I would check fuel pressure first... possible failing fuel pump.... can "free rent" fuel pressure gauge at Autozones...
97 might have had mix of "return and return-less" fuel systems...find out which one yours is....
"Returns" should read 30 PSI and I "believe" returnless setup should read 65 PSI ....someone will probably chime in to elaborate...
