andypalmer
- June 24, 2006
- Norfolk, United Kingdom
- '99 SOHC XLT
I have a 1998 Explorer 4.0 SOHC with 71k. Since the onset of winter it has started idling oddly. It will idle around 700rpm, as it should, but will occasionally dip to around 500-600 and feel like its about to stall. Also at normal idle there is sometimes a shudder which becomes more noticable when put into drive. I also have the check engine light.
The codes read out were:
P1131 Heated O2 sensor 11 sensor indicates lean
P1151 Heated O2 sensor 21 sensor indicates lean
P0171 System too lean (bank 1)
P0172 System too rich (bank 1)
P0175 System too rich (bank 2)
It has been suggested it may be both O2 sensors, sticking stepper motors or possibly contamination in the manifold.
Anyone cured this before? Any suggestions as I have just had a major service, engine flush, brake pads, fan and auxiliary drive belt tensioner done and would prefer not to throw any more money down the drain?
