1999 oxygen sensor/catalytic converter/vacuum leak???HELP | Ford Explorer Forums
Julie76
Kansas
99 Explorer Eddie Bauer
I have a 1999 explorer eddie bauer, v6 3.4 4×4. Had it a year now.when i first got it it needed a front timing chain guide.put it in shop where they convinced me to just go ahead and replace front timing. I did. In process of repairing it the shop blew the head. They replaced it.when i got it back it had an exhaust gasket(?) leak which my hubby said isnt that bad. About a week later check engine light came on. Code read right bank running lean. Last few months it has been running worse and worse. Gas mileage still ok but frequently acts like its bogged down then suddenly will take off full speed.smells like matches. I know its most likely oxygen sensor. How can i tell which one needs replaced,there are 4. I am at end of my rope financially and cannot afford anitjer shop and can't afford to guess which sensor. I need advice!! Please.
Welcome to the site!
The SOHC V6 motor in these is notorious for having issues with the timing chain components, and the guide likely did need to be replaced if that's what you have. The OHV V6 motor doesn't usually develop timing problems and replacing the guide would be a very minor thing.
It sounds bizarre that a shop would blow a head, or even a head gasket, from working on timing components. That makes it sound like this shop doesn't have a clue what they are doing and your problems have all been caused by whatever else they did while messing with the vehicle. You might try getting the shop to either fix the problems they caused, or have them pay for a competent shop or a Ford dealer to do the work and make it right.
It may just be that they didn't torque the exhaust manifolds that are attached to the heads, or perhaps they didn't bother to use new exhaust manifold gaskets and so the old one is leaking, or they might not have used a gasket at all. Exhaust gaskets are inexpensive and fairly easy to replace with enough tools and time, just removing a few bolts. It likely won't be a cheap fix when paying a shop to do it, but it still shouldn't be anything like a timing repair. Again, I think the shop you went to should fix this for free, or pay to have it done somewhere else, whether it be just re-torquing the manifold bolts to seal the leak, or installing a new gasket. Hopefully the other side has a gasket on as well, otherwise they should install new gaskets on both sides.
If there is a lean running code caused by an O2 sensor, usually the oxygen sensor on the side that is running lean is the one that's reporting the code. I would guess that if it was a sensor, it would be the sensor closest to the engine on the right bank side if that's what side the code is reported to be from.
You need to have that exhaust leak fixed first though, since an exhaust leak can cause the sensor to think the engine is running lean on that side, because some of the exhaust is going out the leak before it gets to the sensor, and the other side without a leak is, by comparison, normal. Repairing the leak may eliminate the code and no sensor replacement may be required.
