alpha
- March 11, 2009
- Minneapolis, MN
- Mountaineer 97
Hello Everyone,
I stumbled upon this forum after Googling for hours. To start I am the proud owner of a 1997 Mercury Mountaineer with 250K on it. A lot of miles but previous owner commuted and all are freeway miles. I took apart my driver side door panel for a window problem that was fixed, but before I put the panel back together, my unlock button stopped working. For a few months before taking off the door panel it was sporadic working some but not other times. Finally it no longer works. I can unlock it from: the key outside, the keypad, Lock/Unlock FOB, and the passenger unlock button. I tested the panel and all four windows work, the window lock works, and the lock button works but not the unlock. I opened the switch and checked it out and everything works in the switch. The three main wires are Black-Ground, Pink/Yellow-Lock, and Pink/Lt Green-Unlock. Bridging ground and lock makes the doors lock, but bridging ground unlock has no effect. I checked for obvious signs of damage but couldn't find any, I traced it into the driver kick panel where It enters a large harness all black taped and from there I'm clueless.
I am wondering from the switch, where does the Pink/green unlock wire immediately go so i can check it at that location for continuity and so on.
I checked all fuses relating to door locks and they are fine, but from some searching here a culprit could be a relay in the dash or engine area or all the way in the driver rear where the FOB unlock thing is (not sure what the name is?) But I'm far from certain what it is.
If someone could point me to where this wire first leads to, the help would be appreciated, This is the first of many 'projects' on this truck and it would be great to get it to work and the driver panel closed up as it is bare metal and wires.
Thank you for a great forum!
-A
-A
