2 rebuilds and only 1,400 miles later, I think more A4LD problems are surfacing!! | Ford Explorer Forums
B94Sport
Geneva, IL
05 Subaru Impreza WRX STi
Here is the background...
My original tranny lasted approximately 123,000 miles until the intermediate band broke, and I proceeded to drive about 2,500 - 3,000 miles with only 1st, 4th, OD, and reverse. Then I got it fully rebuilt to the tune of $2,000, with a 12 month/12,000 mile warranty. 1,000 miles after it was rebuilt, the forward clutches went, I took it back to the shop, the pulled the tranny, and repaired the clutches.
Now 400 miles later, I am noticing that in reverse, I have to make the engine rev higher than usual to get it to move backwards. Backing up on a flat surface at a very slow speed requires 2,000-2,500 RPM. I seriously doubt I could back up a 10 degree incline without hitting the rev limiter. So reverse is slipping, but the shift into reverse is not delayed, nor is there a clunk. What gives? Could this be from a leaking low/reverse servo seal? Or am I going to need to take it to the shop again? I got it rebuilt at a shop near my home in IL, but I am now 315 miles away at school.... If this could be something as simple as needing to replace the seal, I have no problems with doing it myself (have done it before). Honestly, after dealing with them, I think the people at the shop are not too bright, and unless this problem is above my skill level, I'd rather spend the money to fix it myself than take it back to them.
Maybe the band cracked
Rebuilds can use the same band they took out or use a relined one, instead of buying a new one. This is a cast double wrap band that can crack from fatigue. If you still have a good third gear, problem is not located in the high/reverse clutch.
I have mine at a Aamco since they are known for transmissions plus I get a 12month unlimited miles warranty..getting it back today after I fork over $1600 but they are replacing bands, pump, converter and other parts. Hopefully mine wont start to fail after that many miles.
Re: Maybe the band cracked
Third gear is still fine as far as I can tell. This is really ticking me off now. I won't be able to take it back to them for at least 2 months and probably 2,000 miles. I guess I will just make sure to minimize my use of reverse for the time being.
I just had mine replaced less than a thousand miles ago, and it seems as though it is getting louder than before. When I first got it out of the shop, it seemed tight. But lately it seems as though it is slipping a little. Back to the shop it goes.
