Explorer94GV
- January 15, 2002
- Springdale, Arkansas
- 94' XLT 97' XLT AWD V8
Ok i jut put in the mraltenator 200amp alt. in today. Well i got in cranked it over and all was fine. As I am setting my clock on my hu all the interior lights,hu,amps all cut out. So first thing i do is check battery cables they are good and are on tight. Than i check the fuse under the driver side dash and fuse #1 that controls inside electronics and lighting is blown. It is a 15 amp fuse i replace it the minute i put it in it blows again. Than i decide mabe i should try a bigger fuse well i put a 30 amp fuse in and lights come on but very dim and i feel the wire coming out of that fuse and it is getting hot fast. After about 1 minute the wire is smoking some so i pull fuse out. I check around the fuse box to see if any wires are open or touching metal and they are all good. I check the fuse slot itself and it looks fine metal contacts are clean and look to be working. Im stumped here any ideas?
