avidmar1978
- May 26, 2012
- 2000 Ford Explorer Sport
In troubleshooting some other issues, I learned that my Check Engine Light and Check Fuel Cap aren't working. There is also a light out at the top of my speedometer. All gauges are working, and all other lights are working. I attempted to get behind the instrument panel to check the bulbs, but that is a task too big for me to muster. On these, you have to remove the steering wheel and lower the steering column. No thanks.
I turned my efforts to the wiring, hoping I would be able to trace this to some accessible wires. I checked out a wiring diagram see that wires for these lights work their way into the PCM, so I started digging around up there. I found a nice reference photo of the PCM here:
http://www.explorerforum.com/forums/showpost.php?p=2469168&postcount=8
Notice the Green and Blue arrows in the pics on that link. Now take a look at mine:
Apparently the previous owner had a thing for clipping wires...
How should I go about re-grounding this, since I'm missing both the bolt it should be grounded into, as well as the grounding strap?
