63tnt38
- March 7, 2008
- 99 Eddie Bauer
I have a 2000 Ford Ranger 3.0l V6 2wd, supercab, Front Coil springs. I just had the front shocks replaced, now there is a metal on metal clunking noise, upon inspection it looks as if the top nut on the shock is not tightened correctly, causing the shock rod to move around in the upper control arm. Should the nut be tightend down on the washer so as to suffiecently sandwich the upper control arm between the upper and lower rubber bushings? If so is there a torque spec.
