2001 Explorer Sport - Rear End Vibration | Ford Explorer Forums
COGTFO
Longmont, CO
2001 Explorer Sport
Rear end vibrates when coming to a stop. Begins once the RPMs drop to around 1k through final stop. Only time it currently occurs.
Front and back rotors and pads are new. Was suggested to me could be a differential issue? Automatic transmission. Occurs in 2 and 4x4. Ideas are appreciated - TY
My usual go to for checking for vibrations is to put the truck on jackstands and put it in gear. Then i remove wheels to see if it solves it. If not i do brakes. If something is out of balance you can usually see it oscillating.
Strange tho cuz usually out of balbance thing vibrate at higher RPMs. Could be powertrain related. But having it jacked and running will let you inspect much easier. Good luck
Thanks Bmalone, much appreciated
