brentoleary
- April 14, 2006
- Wylie, TX
- 2001 XLT
I have a low mileage (43K) 2001 ranger edge 4.0 litre w/ a 5r55e that is acting up. will not shift at normal point on 1-2 under light accelleration (revs to 3500+ and drops in gear shaking the whole truck apart- very disconcerting) shudders on 2-3. It is a 2 owner truck (bought it from my Dad at 24K about 1.5 years ago) so I know it was never driven hard. Neither of us ever towed anything with it and just commuted ~15 miles to work at < 50 miles/hour.
Anyway I read the 5r55e valve body rebuild diary and figured I would try the Ford blowoff valve and new separator plate upgrade last weekend. Unfortunately when I dropped the pan I could see that it already had the blowoff valve installed. I dropped the valve body anyway and put in the new separator plate making sure to torque it back per the instructions. I also noticed there were no (none/zero) metal shavings on the magnet in the pan and the fluid was generally red and new looking. So I have a hard time buying a catastrophic failure.
After I put it back together it seemed to run a bit better (different is probably a batter description), for a few days, but it is starting to act up again a week later. I dropped it off at a shop today and they say I need a full rebuild. I am trying to decide if I drop the $1500 plus, or give it another shot. Any thoughts? Any recommendations for a reputable shop/second opinion in Dallas, TX area?
Also - if anyone needs a new blowoff valve/ford tsb kit I have an unused one I'll make you a deal on
Thanks
Thanks
