2003 explorer front end noise | Ford Explorer Forums
joeyjak
jupiter, fl
2003 ford explorer
I have a 2003 explorer v8 all wheel drive. I am getting noise from the front left like there is a bad bearing. replaced hub assembly but no improvement. tie rods on upper control arm are shot, but I cant imagine it making the noise. when I put it in neutral and coast noise is still there. get a clicking noise on top of the grinding noise at times. also, can anyone tell me the possibility of converting it to 4 wheel drive? thanks for any help
You've got a cv axle going out cost u about 80 bucks for a new one just replaced the rear driver axle in mine it was popping and as for the 4x4 u can do the brown wire mod I just did the mod today very simple
hey. thanks for the response. is yours all wheel drive? im confused on what the brown wire mod is. gave me a great spot to start
Not sure on the difference mine has the auto high and low 4x4 buttons on the dash my brown wire was right under the dash on the passenger side all I did was cut it and added t toggle switch worked great now my front end doesn't try to engage when the rear tires spin. Lol
I have a 01 sport/track front end noise.brg`s good,but did feel a slight clicking or a dull klunk when I spun the Hub,coming from the front 3rd member,thinking it`s a loose ring gear?thank`s /it`s got over 200,000 mile,s on him and run,s like a the day I got it.
