2005 explorer transmission fluid change | Ford Explorer Forums
there is no dip stick ,
But there IS a tiny plug in the bottom of the oil pan, which is intended as a check point for proper fill.
If transmission is a 5R55S, there is a removable plug in the right rear side of the transmission itself, above the top lip of the pan, through which fluid may be introduced. imp
