mayfieldm
- July 21, 2012
- Scott AFB, IL
- 2005 Ford Explorer
Greetings Explorer World,
Here is my issue. My passenger side window will not go up. It gets more complicated. The driver side control will not move it up or down (made sure the window lock was disengaged). The passenger side control will move it down but not up. This issue exists whether the car is on or accessory is used; doors open or doors closed.
I have taken apart the door panel to gain access to the power harness to the motor. I pulled a dome light out...connected two paper clips to it for leads and inserted it into the power window motor harness. Sure enough the same results. The light will only turn on when the passenger side window control is pressed down.
This led me to this forum. I came across many of the forums discussing a broken wire in the driver's side door boot. I removed the boot and both thick blue (black stripe) and thin blue (black stripe) are rather snug and there are no visible breaks. I will say that I have not removed the driver's side door harness from the fuse box etc. Therefore I haven't confirmed if the there is a possible break up by the firewall.
This is where you all come in. Hoping someone can offer some advice and where I can go from here. None of the wires in the driver's side door boot looked damaged, but are there other wires I should be looking for? I am by no means an expert. Please help out if you can. Thanks!
Matthew
Matthew
