Hi, wife's 2005 expolrer has intermittently not started for about the last year. when you turn the key over nothing works as far as ignition. The gauges and lights on dash test out ok, anti theft light is on and not flashing. When it would do this if you cycled the key switch 4-5 times it would eventually start. After the truck started the problem may not show up for another month or so. We have replaced the ignition switch and the key transceiver ring. I have cleaned all ground connections on the fender and fire walls.
As of yesterday the explorer will not crank at all. What ever the issue is seems to be permanent now.
Has anybody heard of this issue? Any help would be greatly appreciated
