Odd Job
- September 14, 2016
- 2006 Explorer Eddie Bauer
I have a 2006 4.0L 2x4 and I can't seem to figure out what to do next. My explorer has a rough idle, and from time to time shows a P0303 misfire #cylinder code. Above about 1500 RPM nothing is noticeable other than terrible fuel economy. It began with a slight hesitation at idle without codes. About two days later a P0303 showed up so I changed plugs, and wires and ran sea foam through both vacuum and in the fuel tank. Still had the code after erasing DTCs. Took it to the shop and they tested for spark and found there to be strong spark. They changed the #3 fuel injector. No change. They also checked cylinder compression to be 150psi (not sure if they compared it to other cylinders and not sure if they did a wet compression test) and checked for vacuum leaks with none found. The code went away but the rough idle still existed. I've changed the fuel filter, EGR valve, and cleaned the throttle body.
Of note I've also seen a P0174 Bank2 system too lean code. I swapped the left and right upstream 02 sensors and the code cleared however looking at long term fuel trim, bank 2 tends to be about 19-20 at idle. Above idle it gets as low as 3-5. Bank 1 at idle is showing <10.
I'm at a loss for what is causing the misfire. It seems to come and go but I've gone through what I know for ignition, vacuum or fuel system problems (by the way fuel pressure/vac is showing 40psi).
Has anyone seen anything like this or have any ideas?
