RPFLimited
- December 9, 2014
- South Florida
- 2006 Ford Explorer Limite
As described, I have a very odd problem.
When I drive this 07 Explorer V8 4x4 (My mom's car, we love it.), I notice there's a slight whirring noise from the front driver's side wheel. As you go faster in the car, the noise speeds up. I did the neutral trick (noise still there when in neutral on the highway) and I've braked on it. When I brake, it goes away. But there's a bit of a shudder when I brake at the higher speeds and it's whirring like this.
I popped off the wheel and checked out the brake. Everything looks fine. Caliper looks okay (a very small chunk is missing from the top piston but otherwise okay) and the rotor looks great.
I put it all back together, and nothing seemed loose. Yet, on the highway, Im still hearing the noise (although it must be my head, because I think it sounds a little quieter this time...)
Any ideas? I thought maybe a bearing/hub assembly but since braking gets it to stop, I figured something wrong with my brake assembly. Perhaps a new caliper is needed?
