2007 XLT - Check Engine Light | Ford Explorer Forums
07EXP
2007 Explorer XLT
I have an 07 Explorer XLT. I have a few codes that I need to address. They came on at the same time. I've cleared them, but they return. I'm getting a P1633 (keep alive memory low voltage) and P0446 (Evaporative Emissions System Vent Control Circuit).
My understanding is that they are on the same circuit. The #24 fuse is not blown. I believe I should check the PCM harness to be sure I'm getting 12 volts at the KAM pin. The problem is I don't know which pin to check since I can't find a diagram with the pin numbers. Does anyone know which pin is the KAM circuit?
