2008 Explorer XLT 2WD 4.0 Stops Shifting | Ford Explorer Forums
jaott02
Hello,
I bought the truck with about 35k miles.
Around 90k i noticed very hard jolting when shifting from park to reverse.
I just crossed over 100k and these problems joined in...
Slight jolts between 1st-2nd-3rd gears.
9 out of 10 times that I get it up to 45 mph, the rpms skyrocket and the truck starts to deccelerate.
Sometimes letting of the gas for a few seconds and trying again will work, but usually im 3rd gearing it at 35 mph all the way home.
I noticed if I turned o/d off, the latter issue does not happen as much.
There are NO flashing O/D lights as Ive read about. NO check engine light. The wrench tool light came on once for about a minute one time. I pulled over, shut it off for 5 minutes and resumed home without any lights.
I drained the fluid, took out the solenoid black. It looked fine, for whatever that's not worth....I checked the connector for water intrustion, everything looked fine there.
Any other ideas? Because my next thought was to go shell out $450 to ford for a new solenoid block
It is not the solenoids, it is the synchronizer in the transmission. Time for a complete rebuild on the transmission.
