Viper Driver
- September 17, 2017
- Ohio
- 2017 Explorer Platinum
Inherited my Dad's 2010 limited. V6. Fuel gage consistently reads low. Have spent tons of time looking online for where I can find the wires that run from the fuel sending unit in the gas tank to the instrument cluster. I'm trying to avoid dropping the tank and/or getting to the C434 connector location basically on top of the tank where the wires come out. My 85% belief after researching is the wire colors coming out of an OEM pump/sending unit are Yellow/White and Black/Orange. I would expect to find those colors at the connector on the back of the instrument cluster, but don't, so either those aren't the right colors or the sending unit gets run through some other location for "processing" before heading to the instrument gage. Supposedly there is a connector with these 2 wires in it located in either the passenger side or drivers side foot kick panel. Looked both places and no luck. Any info, especially with pix would really help. My plan is to get a variable resistor pot to put in the line to see if that'll fix the issue. No codes. Everything acts like it should except it's all about 4-5 gallons low on the gage than what's in the tank. The flow meter that calculates gallons used seems to be quite accurate when compared to fill ups. As an example, when my gallons used meter shows 15.6 gallons used, the fill up is 16.2 gallons, gage needle is solidly in the middle of the "E", and the computer shows zero "0" miles until empty with the fuel low warning on. At completely full via top off at the gas station, the needle will get to roughly 7/8.
I have also not found what gives me much confidence in which direction the sending unit works; i.e. empty is a low ohm reading or high with full being opposite. I'm assuming for purposes of what I want to try, is full is the high number. If I can find the right sending unit wires under the dash, I plan to install a simple and cheap 100 ohm variable resistance pot and go from there. Worst case, I should be able to leave it on zero and still use what I have been. Also have read a bunch of high level info written by what appear to be electrical engineers on all the "what if" pieces of doing what I plan, with all of the outcomes bad. I'm going for something simple. If the gage is looking for 180 ohms full but is only seeing say 160 for whatever reason, if I put a pot in the line (series) to give it another 20 ohms, maybe it's a win? Or maybe I fry the entire instrument cluster...
