2010 XLT Reverse Gear & Parking Brake taps. Need help | Ford Explorer Forums
bmwboyee
First off this is my first post and wanted to say thank you in advance for the community and knowledge that is here. I have tried to search and I can not find the answer in which I need.
I am installing a Parrot Asteroid Smart into a 2010 XLT without sub or sync. I will also be hooking up a reverse camera. All wires are ran and the harness is built. I have two wires that I am having problems with to make everything function correctly.
Coming from the Parrot, I need to tap into the Reverse Gear and Park Brake. They are separate wires. Where can I tap into these wires? On the side of the shifter I do see three wires but I am not sure where they are going.
Again, thanks for the help.
You might want to try posting over in the audio/navigation area, some of those guys might get back to you quicker. Haven't seen anything posted over here before on installing these systems. However, since you can get backup assistance sensors/camera from the factory there has got to be a wiring harness with everything on it that the factory uses.
Thanks for the help. I posted over there. Regardless, I have an appointment to have it professionally installed.
