QCFord
- May 7, 2023
- Location
- Quebec
- Canada
- 2013, Base FWD
Hello everyone,
I'm knew here, but I know there were several thread on the hardwiring of dashcams... Sadly I could not find what I needed.
I recently purchased a VIOFO dashcamfront and rear cam for my Ford Explorer 2013 and I'm having trouble finding the right fuse to hardwire it. I've tested with an meter several fuses, but I'm worried about plugging it into an existing and important fuse and potentially causing damage to my vehicle's electrical system. I need one fuse always on for the camera to work on parking mode. Do you know what fuses to use safely? This version of the car is with limited accessories so maybe I have many unused fuses...
I'm now considering using an OBDII cable adapter that has a mini USB male-end so that the camera gets its power. Has anyone here had any experience with wiring their dashcam using this method? If so, can you please share your experience and provide any advice or recommendations? I'm also concerned about the OBDII connector draining my car battery.
Additionally, I'm worried about the airbag blowing out while hiding the wires to the camera along the sides of the windshield and other areas... I'm concerned so I'm thinking about disconnecting the battery while dping it. Would unplugging only negative on the battery suffice? Does anyone have any advice on how to avoid this problem?
Finally, I would appreciate any suggestions on where to find a professional installer in my area who can help me with this installation. I'm located in Quebec, Canada...
Thank you in advance for your help!
I know a thread existed a while ago about this. I'm sorry to revive this topic,
